  #21 (permalink)
Old 09-11-2016, 11:02 AM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by G-Pete View Post
Yes they have, SAE DOT IST 14 is the marking on the bottom of the lens.
I got them and tried them out, they work great and unlike other LED lenses they are not purely directional. You can see the light from different angles too.
It lights up the whole light and the brake/stop light is very bright.
Thanks again for the find strictlypersonl!!
Pete - FatBoy is offering a different tail light than the ones you and I ordered on Bob's recommendation. Apparently they don't have DOT lenses but that probably isn't an issue in a lot of states - Arkansas would never know. The yellow turn signal would be different - appears to be OK in most or all states.
But as I understand it, on cars such as ours that use a trailer relay to run the brake and signal lights on one wire lead, we would have to re-wire to separate the circuits to use his lights.
But - a couple good options now besides those pesky LED replacement bulbs.
ERA 782 Running
