  #22 (permalink)
Old 09-12-2016, 03:04 AM
FatBoy's Avatar
FatBoy FatBoy is offline
Cobra Make, Engine: Kirkham #523, 427 S/O
But as I understand it, on cars such as ours that use a trailer relay to run the brake and signal lights on one wire lead, we would have to re-wire to separate the circuits to use his lights.
Hi Dan,
You're right, but it's very simple and straightforward. The Kirkham uses the same setup, so you simply remove the connection from the brake light switch that goes to earth and run a wire (available with the lights) from that connection to the brake light wire (green/purple) on the light units and you're done.
Paul
