Old 09-12-2016, 11:29 PM
Ace23 Ace23 is offline
Cobra Make, Engine: SPF#1867 , KC427
Looks like a 10.5" diaphragm plate with a 500 series disc. Rated for 525-550 hp.
Originally Posted by RET_COP View Post
Probably a McLeod super street pro Diaphragm with a dual friction disk. I have the same setup with an Aluminum Flywheel behind a 351w 495HP TKO 600 and 3.27 eaton trutrac with moser 31 spline axles. Absolutely no issues with the McLeod Aluminum 15lb. flywheel and I had the McLeod billet steel in there last year. The response from low rpms is Quicker than the steel FW. I got away from the thought of drag racing to autocross that's why I switched.
What do you guys think about the McLeod Street Extreme? Looks like it is rated for 700hp.
I have also been looking at the gearing calculator and I've spent some time looking at the MPH in all gears instead of focusing on just the 6th...... When you consider the change in tire size going from a 315/35/17 to a 325/50/15 plus the changes in gear ratios the gearing isn't as drastic as I thought it would be. Looks like you need to run a minimum of a 4.10 to make it worth wild.
