Old 05-15-2002, 10:53 PM
Bill E's Avatar
Bill E Bill E is offline
If this picture worked, it shows a AC pump engine compartment that looks good. This is a 460 with Cobrajet aluminum heads, 10 1/2 to 1 compression. The car will run through a parade in 100 degree heat, and never see 200 degrees. The trick is using the right radiator, water pump, and oil cooler. Most of the original looking oil coolers will not work efficiently enough. If you want air conditioning, you have to spend the money on the components that will make it work. A four-core dimpled radiator we find, works the best. We use two 16" fans, a pusher and a puller, rated at 2900 cfm each. The AC will run cool enough to freeze your nipples off, and works very nice with the tonneau cover on the passengers side. E-mail me and I will send you pictures. Bill E. EMS P.S. It gets hotter in Redding CA, than in Texas
Bill Emerson
