Old 09-13-2016, 09:59 AM
cycleguy55's Avatar
Originally Posted by RedHawk View Post
"This is because after they realized that the parts ordered weren't going to simply bolt on they decided to cut the existing tower brackets and fabricate their own."
"This past weekend I diagnosed that the alternator diode was bad. We again confirmed this after the alignment was finished today. I know this can happen at any time its just suspect that it happened on their watch. Hard to ignore when so many other things were improperly done."
Presumably the shop's fabrication of new tower brackets involved welding on the new ones. If so, I believe the process of welding could easily damage sensitive electrical components such as the diode and/or other components unless proper precautions are taken (e.g. disconnecting the battery).
Coincidence? Possible. Cause and effect? Probably.
Brian
