Old 09-15-2016, 04:57 AM
rbgray1's Avatar
rbgray1 rbgray1 is offline
Tom,
Great news!!!! You have two full sets of both the latch covers AND the inner door jamb fronts and toe kick covers!
The large square pieces are left and right toe kicks, these are to be wrapped in carpeting and screwed into the cowl bar during interior install. If you are going to use a stereo with 4 speakers, these are also good pieces to mount 6" round speakers into. I made a small square aluminum "cone" that fits in to the cowl bar area to protect the back side of the speaker that fits into the square opening in the lower cowl bar. This also hides the back side of the speaker when you open the door, painted black you can't tell it's the back side of the speaker. Some foam lining with adhesive on the inside will keep the sound from being "tinny" due to the aluminum "cone".
The smaller rectangular pieces are critical, they need to be bonded on to the front inside of the left and right door jamb area and mate the body with the cowl bar upright. I'd recommend using "vette panel adhesive" on a clean grinded surface on the front of the inner door jamb and then these are riveted to the cowl bar. These finish off the inner door jamb area on the front on both sides. Review the build manual, you'll see what I'm talking about. After bonding these to the body, finish the door jamb surface with fiber-reinforced filler (Everglass or Tiger hair) as a base coat and then top with a quality Filler (Rage Ultra).
I'll cut you a deal, I definitely need the latch covers (left and right), I'll make a copy of my tunnel for you if you want to trade?
