  #24 (permalink)
Old 09-16-2016, 12:53 AM
SFSDFGT SFSDFGT is offline
Cobra Make, Engine: CSX 4145, aluminum body and Shelby aluminum FE stroker
Originally Posted by Blas View Post
If and when you add the puller fan(s) be sure to make a totally new wiring circuit. Do not splice them into the pusher fan circuit. Use relays to feed the power to the fans and perhaps add a manual fan switch and fuses. Feel free to contact me if you need guidance.
Done! But thank you. Yep, new circuit with separate relay, activated by thermocouple switch. But I did put a manual switch on my front pusher fans. And when my puller fan kicks on, the airflow causes the pusher fans to spin, anyway.
Only problem now is my dang Girling brakes. They just do not seem to clamp down with proper force on the rotor. It requires an inordinate amount of brake pedal force to slow the car down decently. New masters, new (and softer) brake pads, brake fluid change and gallons bled through the system, and they are only marginally better than before. Only option left that I know of is to try having the calipers rebuilt, a suggestion by Cobrakiwi. But no guarantee that would fix the problem, either. But I'm done working on the car for the time being. Car season is almost over in South Dakota, and I want to enjoy this thing a little bit before the snow starts flying.
