Old 09-16-2016, 04:32 PM
gjkrv8's Avatar
gjkrv8 gjkrv8 is offline
Originally Posted by Tenrocca View Post
Yep tried swapping wires and unhooking speedo. Good info though Guy, the tuner has mentioned most commodores take the vss off the abs sensors now.
Correct, Phil in VIC also had to do that with his CR as his donor VE Transmission didn't have a speed sensor on it. Maybe give that a go. Easy to test as you just take it off one of the front wheels and jack it up and spin by hand it to see if the ECU registers a signal or not.
