Old 09-17-2016, 07:31 PM
razerwire razerwire is offline
Cobra Make, Engine: csx4163 full comp alu. body
The wheel won't move when you take the spinner off if you don't move the car. You can put the spinner back on just fine. I heard him hit the rim which is why I put towel on rim in case I miss. I have changed from Halibrand spinners to stainless Shelby spinners without raising the car. When I change wheels from Trigo to Halibrand Magnesium The car is off ground, I tap spinners on to contact then lower car to finish because I'm not comfortable hitting on suspension hanging in air. I use white lithium grease not anti-seize, for 25 years without a problem, easy to clean up, reapply every time wheels changed . Everyone has their own way I'm sure. You will to.
