Old 09-21-2016, 07:28 AM
Texasdoc's Avatar
Texasdoc Texasdoc is offline
Cobra Make, Engine: Lonestar Classics LS427. Self-built 408W, AFR 195 heads, Performer RPM Intake, Quick Fuel 750, 407rwhp, 479rwtq
Put a heavier spring in the vacuum advance pod. You can get a quick change kit to make it easy. I think quick fuel makes a kit that removes that pod and replaces it with an easily accessible screw. It won't snap open and give that sudden boost.
Even with a heavier spring, you will still open the secondaries. Still doesn't fix your original problem.
