Old 09-25-2016, 01:34 AM
KevinW KevinW is offline
Originally Posted by 66gtk View Post
If that starter isn't perfectly aligned and shimmed do not attempt to make it work or you will be replacing both your starter and your flywheel / ring gear. I would use your stuck tool and tighten things back in enough to remove your tool. Use an open ended wrench?
Thanks, I thought shimming was not needed on Fords, only Chevy's?
Crendon 427, in the making
http://crendonreplicas.com/
