Old 09-25-2016, 12:36 AM
KevinW KevinW is offline
Before you add another tool to the side of your engine, try "jumpering" across your solenoid, which is presumably mounted to your firewall. Use a nice, thick gauge jumper cable for this, not a skinny wire. This is just to see if the starter will crank. It will make a spark if it cranks, so watch your eyes and wear safety goggles.
Thanks Patrick. I used the solenoid that piggybacks on the starter, so its a little more tricky to do under the car, but i do have a spare wall mounted solenoid, so maybe worth trying to bypass and add this in.
I am now wondering if the starter isnt earthing to the engine properly.
Crendon 427, in the making
http://crendonreplicas.com/
