Old 09-25-2016, 06:35 AM
Tommy's Avatar
Tommy Tommy is offline
spatt,
I gave the answer I did because its doubtful the thermostat is causing the problem unless it has failed in the closed position. If you do need a new thermostat, the standard factory item is set for 195 degrees I believe. I live in the deep south where high temps are common, so I opted for a 180 degree thermostat. I like to enter stop-and-go traffic with a little cooler temp so I have more room for it to rise before it gets worrisome.
Tommy
Previously owned EM Cobra
