Old 09-25-2016, 07:12 AM
patrickt patrickt is offline
Originally Posted by KevinW View Post
Thanks Patrick. I used the solenoid that piggybacks on the starter, so its a little more tricky to do under the car, but i do have a spare wall mounted solenoid, so maybe worth trying to bypass and add this in.
I am now wondering if the starter isnt earthing to the engine properly.
OK, I gotcha. You know, even if you have the starter in wrong, misaligned with the flywheel, and generally a RodKnock half-ass type of installation, it's still going to make a good bit of noise when you turn the key if you have 12v+ going to it, 12v- going to it, and it's not broken. I think I might pull it out, bench test it, and then do a careful reinstall.
