Old 09-25-2016, 04:57 PM
lippy lippy is offline
Originally Posted by Gaz64 View Post
Are you willing the inspect the carb needle and seats?
Have the float levels been check recently?
One the needle o-rings could also be damaged.
How much rubber line is between the last fuel filter and the carb?
Absolutely. I've had this carb apart several times, very comfortable with it.
The float levels are good. On a Braswell carb, you actually check them with a caliper to get them spot on, but of course I'll verify.
There is no rubber in the fuel system. It's all Aeroquip PTFE/braided line and hard line. A also cleaned out the lines thoroughly when I installed the system, 3-4k miles ago.
