Old 09-27-2016, 03:46 PM
ACademic ACademic is offline
Does it also do this with engine off? If so then probably a bad booster. The diaphragm may be leaking and allowing vacuum on both sides of the booster, thus the slow pedal return. Bleed them good first just to eliminate air in the lines before you start throwing parts at the problem.
