Old 09-28-2016, 09:14 AM
rbgray1's Avatar
rbgray1 rbgray1 is offline
Originally Posted by Alfa02 View Post
Thank's Rob, for posting these pictures, as per our conversation last night I believe this is the correct way to go with mine before the body is bolted down. As always thanks for your help buddy.
Thanks Tom.
One thing I forgot to mention, when you weld on the strap or gusset on the lower shock mount, leave a small gap near the base (about 1/4"). This is due to the angle of the lower mount and the gap will allow water to drain out of the lower mount and not collect in the bracket causing premature corrosion. See the picture from the ground up of the lower mount, I know it's hard to see clearly.
