Old 05-16-2002, 01:32 PM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
I don't see any reason why you can't use a good pan such as a Canton road race pan with baffles on both sides, 7 or 8 quart. A good windage tray to keep the oil off the crank. If you wanted to be real safe you could install a good oil accumulator. If the oil pressure ever drops below a certain pressure the accumulator will supply oil until you can shut down. The road race pan would also be good for the street.
Don
