  #181 (permalink)
Old 10-04-2016, 04:21 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Hi Bryan,
For the OP, this is a carburettor problem.
For an engine that idles at 16 inches, I don't know why his throttle plates are drilled for a racing cam.
Your rev limiter probably does make it misfire, dropping cylinders out.
Depending on who's rev limiter you have as to how smooth a cut it is.
Some will hold the rpm at what you set, some are rough as.
With a carburettor, you will get exploding fuel in the exhaust while on the limiter.
Remember, you have it fitted to protect the engine.
If you hit the limiter often, you need a visible progressive shift light.
Gary
