Thread: Webers on a 460
Old 05-16-2002, 08:47 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
You can generate enough vacuum for power brakes with independant runner manifolds.. If they didn't have the ability to restrict airflow at less than WOT, then they would have no vacuum, and the enginge would be running very fast. Tap the runners below the butterflies, run 5/16" line from each runner to a common plenum, an 8 port fuel log works..
