Thread: Alignment Specs
Old 10-11-2016, 04:59 AM
joyridin''s Avatar
joyridin' joyridin' is offline
I assume you have the original MGB front end? If I recall, there is no adjustment for caster or camber. So you have toe adjustment only. I think I just set it 1/8" toe-in if I recall.
The rear has adjustment depending on your set-up. I think I have -1 degree camber and 1/16" toe-in?
If you plan on keeping the car for a while and driving it, you may want to look at the FAST front end. Kind of expensive, but definitely worth the money.
