Old 10-13-2016, 11:39 PM
moore_rb's Avatar
moore_rb moore_rb is offline
Cobra Make, Engine: All original, with Chevy engine since 1964
Correct- If you change the bore size on the clutch MC, it changes the length of travel in the slave cylinder rod, as well as changing the clutch pedal leverage ratio.
For that reason, I'm going to swap like for like parts.
One thing I will do is use Dot4 fluid when I refill and bleed the system.
But I'm really bummed that I'm going to miss the Prescott run.
- Robert
