  #29 (permalink)
Old 10-14-2016, 03:44 PM
rbgray1's Avatar
rbgray1 rbgray1 is offline
Redhawk,
My Flaming river column is gorgeous, I ordered a polished, tilt, with no key...going to install an ignition switch with a key on the dash when I rebuild the dash. Probably also going to install a momentary "starter" rubber coated button for the start function.
My column was approx 800 bucks with the drop bracket and aluminum swivel bearing plate for the firewall protrusion. FR also offers in column start button with proximity fob and electronic box controller, I'm just not sure how much this adds to the cost. The reason I didn't go that way is that their controller can operate 6 to 8 functions, power windows, door locks, auto start, etc and I just didn't need all that. Also, keep in mind the polished column is probably twice the cost of a painted unit.
I also am replacing the sector shaft and both U joints in the sector shaft with an FR unit once I start reassembling the car. It was interesting that a car with only 26k on the odometer had a fair amount of play in the joints on the sector shaft. Let me know if you need the part numbers that I ordered from FR. This is a custom length for them but still only took 3 days for them to build. FR is only 10mins from my home in the Cleveland area.
