Old 10-15-2016, 07:36 AM
66gtk 66gtk is offline
Originally Posted by 66gtk View Post
Did some research and here's what I came up with for parts - all Wilwood (please let me know if this is all wrong).
Calipers: Wilwood 120-11130 (symetrical)
http://www.wilwood.com/Calipers/Cali...emno=120-11130
Pads: 150-8854K
http://www.wilwood.com/BrakePads/Bra...emno=150-8854K
Rotors:160-2894 (RH), 160-2895 (LH)
http://www.wilwood.com/Rotors/RotorP...temno=160-2894
Hats: I'm hoping that my current ones will work? If not, any guidance on what I need? Again, I have a 6 PIN setup.
I may also need new adapters and brake lines it seems.
Thanks!
Troy
Bob... Can you kindly shed some light on if you think the above will work / fit? What are the specs on the Wilwoods you are now using to replace the Sierras?
Thanks
Troy
