Old 10-15-2016, 09:51 PM
Karl Bebout's Avatar
Karl Bebout Karl Bebout is offline
I pulled the steering wheel to have more room to work. Wanted to get the steering column out of the way, but will need to talk to Peter, on Monday. According to the build manual, I was doing it right, but didn't have any luck.I did loosen the clamp so I could move the column up and down and pulled the screws/bolts so the dash would drop enough to let me get at stuff. Not all that bad, but maybe getting the screws/bolts back in might be tough. I'll find out tomorrow. Was able to run the Speedo GPS antenna up through the defrosted vent, so it'll hardly be noticeable. Wiring is all done but hooking up a constant hot and a keyed hot. Speedo looks good and has a lifetime warranty.
Karlos
