Old 10-17-2016, 06:11 AM
Wisconsin_Snake Wisconsin_Snake is offline
Cobra Make, Engine: Classic Roadsters, 95 EFI 5.0
For the body positioning question, I can answer that.
This happens when you mount the firewall. When first putting the firewall in, initial thought is to push it forward up against the frame eliminating any gap between the frame and the firewall.
What should be done is to push the firewall backwards against the crowl bar, then fasten it down. Unfortunatly this is one of those many things not mentioned in the manual.
If you look at the blue cobra at the pic with the driver’s door open, you’ll notice that the dash extends ~1 inch past the upper door opening.
