Old 10-18-2016, 11:23 AM
strictlypersonl strictlypersonl is offline
Originally Posted by 66gtk View Post
Thank you. Much appreciated! Yes, I have the 6 PIN system. I'm not sure if the HATs currently on the car are from the original Sierra installation my car came with from ERA or the PBR that is currently on there. I was thinking/hoping they would work with the Wilwoods I specified above?
Also, if it helps nail things down better, these particular calipers are available in either a 1.25, 1.38, 1.62 or 1.75 Bore size. If they fit, which would work best with the master cylinders I have stock - installed on #488?
All this information will help me get my car closer to putting 15s back on there without having it be cost prohibitive. Again, I really appreciate the technical assistance!
It looks like you're using our hat, so the conversion to smaller discs shouldn't be too hard. You might even be able to use your current caliper (assuming it will fit around a 1.25"-wide rotor), if there's room to move it in 1/2" with a new bracket. Your rotor number should work, but we use the heavier-style 160-11836 variation.
