Old 05-17-2002, 07:37 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
Jim, I use the Comp Cams Extreme energy cams in all my motors. The Fords really like the split duration of the Extreme cam. For the non strokers I use the Comp 35-246-4, for the strokers I use the 35-250-4. Both have a semi-radical idle and perform great. The torque curve on the dyno is almost peak from 2500 to 5200 rpm. They make tons of torque and you never have to rev above 6k for peak performance. I like the torque curve low because that's where most guys want it. Since you don't need to rev the engine over 6k it saves on parts and potential higer rpm damage. If you are interested I can give you the specs.
Don
Just a note on cams. I have tried over 20 different cams and head combinations on the dyno. The Comp always comes out on top.
