05-17-2002, 08:12 AM
FL
Cobra Make, Engine: CMC, Supercharged Ford 5.0 & all the toys.
BTW, get the stock gear (stock # of teeth). You usually change to different # of teeth depending on rear gear ratio and tire dia, but many times have problems due to the teeth not meshing correctly -- it eats the gear up. Since you have an electronic speedo, it should calibrate-able via some DIP switches etc in the back. If so, get the stock gear and adjust the speedo.
-Neil.
www.VEIsystems.com
CMC Cobra, Ford 5.0, EFI, Vortech supercharged, T5Z, 8.8 rear, MII front, 4-wheel discs, A/C, stereo.
