Old 10-21-2016, 07:05 AM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by wolf k View Post
Dan, if what you have does not work, a small dab of Permatex Right Stuff on the sealing areas should do the the trick. Whatever formula Permatex has come up with for Right Stuff is much improved over RTV sealants of the past.
The ships I sail on do not leave port unless we have a case of this sealant onboard.
Thanks, I put a small dab of high pressure pipe thread sealant on the threads and sleeve. So far so good, but I left the gage loose in the dash so I can pull it out and check it for a few weeks before feeling comfortable with it.
Good info to know about the Right Stuff.
ERA 782 Running
