Thread: Engine help
Old 10-22-2016, 02:28 PM
Phx Mike's Avatar
Phx Mike Phx Mike is offline
Cobra Make, Engine: Ex owner of a polished Kirkham 427 S/C. Now Cobra-less and driving a mid-engine German hot rod.
Given what you are seeing on the tach I am thinking it is an electrical problem. Since it starts back up after you have the problem and then has the problem again later, intermittently, I would check your ignition switch - it may have an intermittent contact when in the run position. You might try starting it and slightly touching/wiggling the ignition key a bit and see if that prompts it to act up. If in doubt, check the connections on the switch and replace it.
