Thread: Lsd or not
Old 10-24-2016, 12:13 AM
dave295 dave295 is offline
Cobra Make, Engine: Evans chassis, jag fr. & rear.
First see what ratio your diff is.
Count the teeth on the ring gear (rg) and count the teeth on the pinion gear (pg).
Using a calculator divide the rg by the pg and that is the ratio.
The Salisbury diff fitted to a Jag had a small plate attached by one of the rear cover bolts.
This plate (if still attached) would give the teeth count for each gear and/or the diff ratio.
Search engine (google) Jag diffs. You'll learn heaps.
Dave
