Thread: Air Cleaners
Old 11-03-2016, 08:29 AM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by Detroit Bill View Post
I am sure you have seen this but in case you have not?
Second Strike Air Cleaner Calculator
By this calculator you are OK with two paper filters. It is interesting to swap in the oiled felt filter and see the difference.
I have this setup at present, when I first saw photos of it I did not like the look of it.
It grew on me over time. I am a bit of a function over form type guy.
I did the calculations in the past and the top does add quite a bit of surface area.
Good luck!
Surprisingly when I plug in my two S/H filters (8.5 inch x 2 inch x 2each), my engine size (459), peak power (480) and rpm (5400) I get 1% pressure loss and 4.8 HP loss at 5400 rpm. That's better than I expected. Makes me think the calculator may be a bit optimistic.
ERA 782 Running
