Old 11-03-2016, 02:46 PM
CompClassics's Avatar
CompClassics CompClassics is offline
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
Nice, other than the reverse radius tubes mounted at the door latch post area the frame can easily be adapted to a street Cobra configuration. There are other things like, the oil cooler mounting brackets, the roll bar mounting brackets and the 427 style radiator cooling fan brackets that can be removed as well. The 427 cooling fan bracket should just be a bolt on application anyway.
