Old 11-08-2016, 09:45 AM
lippy lippy is offline
I just had another MSD episode. The magnetic pickup on the dizzy went bad. Just for kicks unplug your dizzy and measure the resistance across the two pins. If it's above 1300 ohms then it's bad. Also check the LED on the box to see what it does when you turn the key and crank. If those things check out do the MSD spark test to see if you have spark.
