Old 11-10-2016, 07:01 AM
moore_rb's Avatar
moore_rb moore_rb is offline
Cobra Make, Engine: All original, with Chevy engine since 1964
Originally Posted by Car Nut View Post
I see two issues.
The timing marks on many aftermarket dampers aren't indexed correctly to the timing tab on the passenger side of the engine (when using a driver side water inlet for the water pump). They were designed for a tab on the drivers side. Not sure if yours is this way. You can check this by putting it on TDC (between the compression and power stroke) and checking the mark.
Yeah I confirmed that my balancer is indexed correctly to my pointer (mine is driver's side)
I have the same distributor. I run a base timing of 18 degrees with a total of 36 degrees. The vacuum advance adds another 20 which makes it pop and snort over 2500 rpm in cruise. That is just way too much timing for my motor. I run it without the vacuum advance and it performs just fine. Could it be that someone put a stop on the vacuum advance and it fell off?
This is great info... thanks!
I also saw 20 degrees added by the vacuum cannister, so good to know that my dist. is acting the same as others of the same model.
I am leaning toward the same conclusion as you about the vaccum advance on mine being "impeded" before saturday night, and suddenly having something work loose which allowed it to go full vaccum. I didn't see anything loose floating around inside the dist. housing when I had the cap and rotor off it, but I'm going to take a second look at that, because I think you are onto something....
- Robert
