Old 11-14-2016, 11:52 AM
bobcowan's Avatar
bobcowan bobcowan is offline
This is the route I plan to follow.
The stock Coyote makes about 435hp. To the rear wheels you lose about 15% or so, now you're down to 370'ish. But we live in CO, and you lose about 2-3% per thousand feet. I live at 6,200' ASL, and frequently drive above 10,000' ASL. On a hot day at altitude you're down around 300hp. I agree with you, not nearly enough power.
I'll start out with a stock 11-14 Coyote. I'll pull the heads off, and do some mild upgrades - P&P, springs, ARP studs, and MLS gaskets. Probably don't need all that, but a little extra insurance.
I'll use a Roushe stage 2 kit, with a slightly smaller pulley. Roushe has a good reputation fro programming. That should put me at about 620'ish hp at the crank, 530 at the rear wheel. With a supercharger, the correction factor is significanly smaller. My FFR made 515hp on Lou's dyno, with the correction factor. I'll be happy to be making more than that.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
