Old 11-15-2016, 07:23 AM
monster7 monster7 is offline
Cobra Make, Engine: Hawk 289 USRRC, 302 Ford
Originally Posted by Jaydee View Post
I was told by my radiator guy that if the flow is to fast , then the coolant doesn't get a change to cool down, because it goes through the radiator to fast. So the thermostat serves as a restricter as well as regulating the temp.
JD
This is correct from a physical point of view, also true for water (heat transfer rate)! If the flow is too high, the heat transfer rate will decrease, also the efficiency will do so.
