Old 11-17-2016, 11:09 AM
blykins blykins is offline
Just to address those...
These days the Pond aluminum block is $5600 and up. Shelby is about $1000 higher.
BBM iron block is around $3500 I think.
Absolutely no issue whatsoever with running aluminum heads on cast iron blocks. Zero. There are actually more chances of leaks with the all-aluminum FE engines than the cast iron/aluminum pieces. Plus, I recommend that all my all-aluminum customers run Moroso Ceramic Seal through the tank on an initial install. Don't have to do that on a "hybrid" engine.
A lot of your OEM combinations are all-aluminum. However, they have OEM quantity, OEM manufacturing, and OEM foundries behind them. Big difference.
Personally, knowing all that I know, I wouldn't consider an aluminum block a bragging right, but I could see where it could be taken that way. Same way as bragging about having a "6-speed".
By the way, RK, this post wasn't an argument to your points, but just trying to clarify some things out there that could be really considered rumors, as you call them.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
