Old 11-20-2016, 05:59 PM
Jaydee Jaydee is offline
Cobra Make, Engine: CR Cobra 3169
I remember years ago working on V6 Volvo who used a Renault v6. The casting was very thin near the oil galleries. Then when the cooling system wasn't maintained properly, it would corrode into the oil gallery and fill the entire cooling system with high oil pressure. Destroying the radiator, heater core and a hell of a mess to clean up. Just removing heads was tricky, if you bumped the sleeve it would break the paper gasket at the bottom of the sleeve.
JD
