Old 11-21-2016, 03:51 AM
ha_pe_1968 ha_pe_1968 is offline
Cobra Make, Engine: SPF 2234 Diamond Edition, Roush 427R
Hi Bill!
Removal of the tunnel will be one possibility, removing the engine an other.
I decided to let the tunnel and the engine at its place. Have a Roush 427R too and a TKO600. It was very tight - but after doing it i know it is possible to remove the transmission without removing the tunnel. Move it back and up at the back as much as you can and you can slide the transmission out. Nothing against removal the tunnel...but i prefered to not mess with the sticky sealing around :-)
If you have the clucth out replace the pilot bearing too.
Regards
Peter
