Old 11-25-2016, 09:53 AM
RodKnock's Avatar
RodKnock RodKnock is offline
Originally Posted by olddog View Post
I think Brent's reply should be:
So you want to spend $2500 to loose 125 lb and consider the 30 Hp loss insignificant. At a 4:1 weight to Hp ratio a 30 Hp loss is equivalent to a 120 lb gain in weight. So your willing to spend $2500 for an overal gain of 5 less pounds to accelerate? I could use a good laxative the night before a race to achieve the same results.
I have to be honest:
The smart ass comment above was to make a comical point. Without the emoticons, it looks like I'm piling on. The point is true if drag racing. In the twisty turns, the hole 125 lb matters and you cannot apply much power in a corner. However accelerating away we're back to the 5 less pounds to accelerate thing.
Pond prices his alloy and cast iron blocks exactly the same. From memory, BBM charges $1,000 more for an alloy block. At the time, my Shelby block was $1,000 extra. But Shelby has probably priced themselves out of my engine build, if I were in the market today.
And as I said earlier, I can compensate for the alleged loss of 15-30 HP in the engine build or even a chassis dyno tune. It's awfully difficult to lose 125 lbs from my Kirkham. And it's not an either/or proposition for me. I want both, the reduced weight and the extra HP from the build and the chassis dyno tune.
