Old 05-19-2002, 06:53 AM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Ditto SpecialK, above with your setup. Ground the wire going to the temp sender through a dash toggle, then to a chassis ground.
I have a Ron Francis Wireworks dual relay setup with an air conditioner circuit. The air conditioner circuit kicks the fan in whenever the A/C is turned on. Ran the A/C + lead to a dash switch to manually control fan.
