Old 12-06-2016, 07:46 AM
GBowman's Avatar
GBowman GBowman is offline
Cobra Make, Engine: BDR #1230/B2 445CI SBF
Late to the party here...but...I have found a huge benefit in my elec water pump (Meziere) is that when I shut down I can turn the key on and have water pump & fan run for a couple of minutes with the engine turned off in order to mitigate heat soak. This is a huge up side if you do any restaurant hopping and only shut down for an hour or two at a time. I've had heat soak issues in the past and this has cured that problem 100%.
Gary Bowman
Voorhees NJ/Key Largo Fla/Ventnor NJ
