Old 12-09-2016, 07:38 AM
MISFIT 1 MISFIT 1 is offline
Originally Posted by Tommy View Post
My favorite way to check for a bad ground is to run a temporary jumper cable from the negative pole of the battery to the frame or whatever piece is your central ground. If the symptoms go away, it was because you have a bad ground. If the symptoms remain, it is something else.
Good idea! I will try this weekend and advise you guy
