Old 12-09-2016, 08:49 PM
Ct_Cobra Ct_Cobra is offline
Cobra Make, Engine: Antique & Collectible Autos, Inc.
Default Doors
Originally Posted by H-Rod View Post
Any major "pains in the butt" you`ve come across so far?
Past posts in this sub forum have made mention that mounting the doors is a real P.I.T.A.
The only issue I had was the need to remove some material on the inside of the drivers side door lip otherwise it would rub on the front fender when the door is opened up all the way. I covered the fender with 3 layers of plastic tape to protect it while I sanded the back of the door lip with 80, 120, 220, 400 and then 600 grit wet paper. I did this while holding the door almost opened completely. I took extra care to make sure I didn't sand any area that would be visible when the door is closed. Other than that I am very pleased with the A & C kit.
