Old 01-01-2017, 07:29 PM
Blaine Sellie's Avatar
Blaine Sellie Blaine Sellie is offline
Cobra Make, Engine: 2015 Factory Five MKIV
With the above information I have 4 quick questions-
1) would love a quick revving 18lb aluminum flywheel, but would I regret not getting a 30lb steel given its smoother driving?
2) Should I go with the McLeod flywheel, pressure plate and clutch? Which diameter?
3) What horsepower might I expect from this build?
a) as is, with stock heads, Holley 750 DP, comp 270h cam, etc... and what's a safe RPM?
b) adding my Edelbrock heads, comp 274h cam, Harland Sharp roller rockers, same Holley 750DP carb, etc....and what's a safe RPM?
Thanks in advance!
Blaine
2015 Factory Five MkIV #8613 (build in progress)
IRS, Pin Drive, Trigo's w Avon's, FE 428 with bolt-on's
2008 Mercedes S550 Kleemann (White)
1988 Porsche 930 Factory Slantnose Cabriolet (Red)
1974 Porsche 914 Factory 2.0 (Orange)
