Old 01-02-2017, 12:37 PM
Three Peaks Three Peaks is offline
If you're so inclined, the 392 is one of the easiest strokers to build and the parts are readily available. Other than the stroker crank, you can use off the shelf parts or existing 351W parts for the build- 302 pistons, 351W rods (stock work fine), standard ring sets to match the pistons, and everything else matches up to the block- cam, heads, etc.... I built mine this way and I think I only have $3500 in it including hot tank, machining, and all the parts I bought new and it is a great engine and more horsepower than I need for now.
Bob
