  #55 (permalink)
Old 01-04-2017, 05:01 PM
john chesnut john chesnut is offline
Thank you for the picture. I think it's a beautiful car.
I want to have easy access to everything so I want to be able to remove the dash easily.
- I hung a strip of birch plywood under the foam to support it.
- I cut, shaped and notched the foam to fit the body and to meet up with the interior glass line.
- The dash will bolt to the side of the cockpit with the top resting on the foam (2 sided tape). The edge of the dash will fit the glass line to finish it off.
- There will be steel posts bonded to the sides of the windshield frame. The posts will bolt to the frame. I will be able to quickly unbolt the frame and remove the glass with the fiberglass surround. Then I will be able to insert a full height frame with full height glass. The glass is 63-67 Corvette.
- The glass work on the body is done. It can be removed now for glassing the underside. Then body work.
