Old 01-05-2017, 02:06 PM
Texasdoc's Avatar
Texasdoc Texasdoc is offline
Cobra Make, Engine: Lonestar Classics LS427. Self-built 408W, AFR 195 heads, Performer RPM Intake, Quick Fuel 750, 407rwhp, 479rwtq
Well, crap.
Just got news from the machine shop that all the guides are worn. All of them. I need 16 new guides. There is over 5-thousandths play in them. 7 (out of 8) of the intake valves also need replaced - they have visible/palpable wear on the valve stems. All the exhaust valves are ok. they tested the new springs and they are all functioning normally.
I don't know what is up with these heads. I bought them "new" from Jegs. First - multiple spring failure. Now - multiple guide and valve failure. I made sure to line up the pushrod guide plates so the rocker tips were centered over the valve stems. I used a push rod length checker to make sure the pushrods were the right length. The rockers have a small line in the center of the valve tip with the Sharpie trick. Unless there is a side-to-side geometry error with the casting of these heads, I'm not sure how I would get wear on the sides of the valve stems.
I have a email into AFR. They will review my email and call me back in a few days. They are trying to catch up from the holidays.
Grrrrrr....
